1993 Air Cleaner Assembly - NCRS Discussion Boards
  • Frank K.
    • January 1, 2000
    • 319
    The Corvette Service manual (Book 2) Reminds you to properly secure the radiator air deflector to avoid water intrusion into the engine. This is completed prior to installing the air cleaner assembly. I see no info in the service book Can some one elaborate on this issue?
  • Kenneth P.
    • November 17, 2015
    • 151
    Re: 1993 Air Cleaner Assembly
    I believe they are talking about the plastic sheeting that goes in the bottom before the air filter box goes in.
    • Kenneth P.
      • November 17, 2015
      • 151
      If your missing it here's one I found on eBay.
      • Frank K.
        • January 1, 2000
        • 319
        Thanks! The one on e-bay does not fit on my 93 coup.Is this picture in book one or two in the helms service manual?
        • Kenneth P.
          • November 17, 2015
          • 151
          Here is the page from the parts books. Item 1 part number 10204532.
          Item 49 in pic is a push in retainer #20032850.
          • Kenneth P.
            • November 17, 2015
            • 151
            Here this should fit.
            • Frank K.
              • January 1, 2000
              • 319
              Thanks! I did see the fastener but it was not attached (one). The other must be attached under the radiator correct?
              • Kenneth P.
                • November 17, 2015
                • 151
                My 90 has no retainer its just sits below the air filter housing inside the engine compartment. I can't find any illustration or pics on how yours would go in. Maybe some one here with a newer C4 could provide some pics.
