Brake pedal push rod location - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2589
    There are two holes in the brake pedal shaft for locating the master cylinder rod. My 66 had added-on 67 style power brakes when I got it and the rod was located in the bottom hole.
    As part of my restoration, I have returned the car to manual brakes. I believe the rod goes in one hole for manual and the other hole for power brakes, but I don't know for sure which is which!
    The attached picture shows as removed, i.e. in the bottom hole, and I pointed out the upper hole with a red arrow.
    I have looked in the TIM&JG, the AIM and the Service Manual and can find which goes where.
    Looking for which hole to install the rod for manual brakes? Also, where is this called out in any of the documentation?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: Brake pedal push rod location
    Use the top hole as shown in the photo of my pedal assembly. I looked in the AIM and only 1 hole is shown for both manual and power brakes. The actual pedal assy has 2 holes.... have no idea why....
    • Timothy B.
      • April 30, 1983
      • 5202
      Don,
      I agree with Stephen, but turned right side up it would be considered the lower hole. The booster changes the angle of the master cylinder so the lower hole lines straighter.
      • Stephen L.
        • May 31, 1984
        • 3162
        No. Installed in the car use the upper hole. The photo has the assy upside down. The AIM makes no mention of an alternate hole for power brakes. I guess that was possibly an "understanding" on the assy line.
        • Jim D.
          • 2885
          Standard brakes and power brakes require a different pedal ratio. If you don't change it when you add power brakes, you'll bounce your face off the windshield every time you apply the brakes.
          • Donald H.
            • November 2, 2009
            • 2589
            Thanks all. I'll use the upper hole.
            Don Harris
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11364
              Can't see in the photos, but if the change by the prior owner to PB included removing the upper arm shaft coil spring and plastic sleeve(not used for PB), I think it needs to go back on for the manual brake changeover. I think this applies to 1966 as well as 1967.
              I have a photo somewhere on Photobucket but I can't find it. On the road so I can't access my home files.
              Rich
              • Timothy B.
                • April 30, 1983
                • 5202
                Stephen,
                The 1963 AIM section J-50 sheet #3 has a note to use the lower hole for the power brake booster clevis.
                • Stephen L.
                  • May 31, 1984
                  • 3162
                  No note in the 67 AIM on any brake pages....... evidently eliminated.
                  There is the addition of a "striker" bolt and nut in 67 power brakes on the J50-A3 page. Don't know what that is....
                  • Donald H.
                    • November 2, 2009
                    • 2589
                    Rich
                    Thanks Rich. I discovered the missing spring and bushing when I was restoring the pedal assembly. Replaced both
                    Don Harris
                    • Donald H.
                      • November 2, 2009
                      • 2589
                      Rich
                      Don Harris
                      • Timothy B.
                        • April 30, 1983
                        • 5202
                        Stephen,
                        The striker bolt and flag goes in the top bolt and it's there to contact the brake light switch on power brake cars.
