Dual points distributor - NCRS Discussion Boards
  • Harmon C.
    • August 31, 1994
    • 3228
    Would a 1100985 dated 8A3 dual points distributor have any Corvette application ? It has a cap with two windows.
    Lyle
  • John D.
    • December 1, 1979
    • 5507
    Re: Dual points distributor
    Lyle, '985 is a 62 carb distributor. But your tag is off unless it's a service replacement. 8A3= Jan 8, 1963 or 1973???
    Need the distributor cam number to see if the 985 original for a '62 or over the counter. Maybe the football number also.
    John D
    • Bruce B.
      • May 31, 1996
      • 2930
      Lyle,
      The 1110985 is used on a 1962 340 HP Corvette.
      But I am sure you would know that.
      Bruce B
        • 15706
        A lot of ...985 distributors were sold OTC to racers and hot rodders for many years after their final OE application on the '62 340 HP engine, so its fairly common to see dates well beyond mid- '62.
          • 43279
          Duke------
          It was available in SERVICE into the mid-1990's. Manufacture probably ended about 1988 when most Delco-Remy manufacturing operations "closed up shop".
