Schwitzer Fan Clutch - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5332
    Question,
    Are all Schwitzer fan clutches stamped with a date? if yes, are there multiple locations?
  • Jim D.
    • 2885
    Re: Schwitzer Fan Clutch
    I don't know if ALL of them were stamped but the judging guide says the date was stamped on the outer edge. The original one on my 65 was stamped on the back surface of the mounting flange so it couldn't be seen once it was installed.
    • Michael J.
      • January 27, 2009
      • 7156
      I have always had mine date stamped according to what the TIM&JG says.
      • Dan H.
        • July 31, 1977
        • 1372
        Think 63/64 were undated, maybe dated by 65? My 64 is undated.
        1964 Red FI Coupe, DUNTOV '09
        • Harry S.
          • July 31, 2002
          • 5332
          The reason I ask is I came across one sitting in an open GM box. It is very dirty and there are three mounting bolts in the box, one missing. I cleaned it up and can't find a date anywhere.
          • John S.
            • May 4, 2008
            • 427
            My March 65 car has an undated Schwitzer fan clutch and my Jan. Built 67 has a December dated Schwitzer clutch.
            John Seeley
            67 Black/Teal
            300 hp 3 speed coupe
            65 Maroon/Black
            35k mile Fuelie coupe
            • Jim D.
              • 2885
              Have you removed the one on your 65 and checked the back side? It's possible that many of the undated ones were actually stamped on the back like the one for my 65.
              • Andy C.
                1963-4 Team Leader
                • April 1, 1998
                • 119
                I have the original on my 64 September car it is undated.
                • Harry S.
                  • July 31, 2002
                  • 5332
                  Sounds like I came across a 63/64 clutch.
                  Thanks all
                  • Ed S.
                    • August 6, 2014
                    • 1377
                    Harry,
                    Is there a 2 letter code stamped in ink on the front of your clutch housing? If yes, what is it? According to the '64 Judging Guide it should be "CJ" and the shaft length should be 1 3/4 inches long. This fan is a Schwitzer acceptable on 63 & 64 Corvettes. JG also states that this fan "is not" dated.
                    Ed
                    • James W.
                      • December 1, 1990
                      • 2669
                      Originally posted by Ed Szeliga (60294)
                      Harry,
                      Ed,
                      My 1964 convertible built in January of '64 has the original Eaton type fan clutch with "CJ" ink stamped on the front side on the fluid reservoir. Can't recall the exact shaft length.
                      James
                      • Ed S.
                        • August 6, 2014
                        • 1377
                        Originally posted by James West (18379)
                        Ed,
                        James
                        I wish I had your fan. The one on my 64 L76 is also an Eaton but it is stamped CK, which according to experts, is for a BB. My shaft is not correct for a SB CJ type fan either. If the one Harry "found" is serviceable I am wondering if he is interested in selling it.
                        Ed
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11345
                          Ed, I have photos in a recent post HERE.
                          And I just measured both shaft lengths(hub face to edge of casting)and they measure apx 1 3/4".
                          Rich
                          • Ed S.
                            • August 6, 2014
                            • 1377
                            Richard,
                            Thanks but.... that doesn't help me. I need a CJ stamped fan either undated or dated prior to April 64. Harry Sadlock said he found one that looks like a 64 in a box, was hoping that he would respond to my question. That said, your clutch units are definitely nice.
                            Ed
                            • Leif A.
                              • August 31, 1997
                              • 3646
                              Richard,
                              Ed,
                              Here you go...CJ stamped K&B Schwitzer repro.
                              https://www.paragoncorvette.com/p-36...utch-unit.aspx
                              Leif
