C1 1962 pros and cons of converting to disk brakes - NCRS Discussion Boards
  • Ed P.
    • August 10, 2014
    • 89
    I am thinking of converting to disk brakes all around.
    Gona use it as a driver.
    What is a good brand.
    Is it hard to install.
    please help
    tank you
  • Terry D.
    • May 31, 1987
    • 2697
    Re: C1 1962 pros and cons of converting to disk brakes
    First question is why? Unless you are planning to do autocross or road racing there is no need for disk brakes! You are not stopping a 6000 pound land yacht. A properly functioning brake system will stop your Corvette just fine. I find most guys who want disk brakes have not taken the time to make sure their brake system is working as it should. Given the cost of a disc brake conversion, sometimes you have to change rims, run new brake lines up front for the dual master cylinder and proportioning valve and play around with getting proper front to back stopping, it just doesn't seem worth it to me! Just my old two cents
    • Ed P.
      • August 10, 2014
      • 89
      thank you terry
      • Frank D.
        • December 27, 2007
        • 2703
        I have a disc brake conversion on my '61 (front only and done by a previous owner) and stock drums on my '63...
        I don't feel unsafe or that I can't stop quickly when required in either car...both cars have single master cylinders...
        • Leif A.
          • August 31, 1997
          • 3653
          Frankie,
          Don't you mean "had"? I thought the '61 went swimming over to Europe.
          Leif
            • 43279
            Terry and Ed------
            I totally agree. While I love disc brakes, if I had a C1 I would not even consider converting to disc brakes. No way. Period. Very little would be gained and a lot would be lost.
              • 11692
              Terry and Ed------
              If Ed were to go and access the original discussion board he'd be able to read the posts from the late, great Dale Pearman. Dale often gave reasons as to why the conversion shouldn't be done, and as I recall a lot of his reasons involved the change in front bearings (ball to roller, I believe). Check out the Archive Board, Ed, and see what you can find.
              • David R.
                • June 29, 2014
                • 183
                I actually considered doing a full disk brake conversion on my '62. I drive it occasionally and show it about six or seven times a year, and on my way home from my last show a nitwit in a jacked-up pickup truck cut me off at about 50 mph - I had to really nail the bone-stock (but well maintained) brakes, and I was entirely satisfied with how quickly and straight the car stopped. I wouldn't do the disk brakes . . . In my opinion, it's just not worth it for what little you would gain. Spend a little going through your stock system and making it as perfect as you can, and you'll be fine.
                • Ed P.
                  • August 10, 2014
                  • 89
                  Thank you all
                  I decided not to install the disk brakes
                  • Frank D.
                    • December 27, 2007
                    • 2703
                    Originally posted by Leif Anderson (29632)
                    Frankie,
                    Not to hijack but yes the '61 is sold and maybe stateside and only an hour north of me - a long, funny story for another thread...
                    • Terry D.
                      • May 31, 1987
                      • 2697
                      Ed
                      Now you can use the money you saved to install a 5-speed and really enjoy that driver!
                      • Eric E.
                        • November 1, 1998
                        • 254
                        Ed, I went through the same mental expercise on my 62 this last spring and finally decided the same thing when I remembered that my old 55 BelAir was drum and never had a problem..
                        • Dan A.
                          • May 31, 1974
                          • 1073
                          If memory serves which is risky. Dale said the bearings used to convert solid axle cars to front disc brakes were from the Ford Pinto. That those bearings were not designed to carry the load of a V8 engine?
                          • Joe R.
                            • July 31, 1976
                            • 4552
                            To answer your question directly.
                            Pro's Your car will stop better!
                            Con's You will decrease the value of your Corvette upon resale!
                            JR
