C1 convertible deck weatherstrip - NCRS Discussion Boards
  • Keith R.
    • August 31, 2001
    • 675
    I've run an exhaustive search on the forum and archives and still can't quite get a definitive answer of where the deck weatherstrip ends at each side of the deck. I've seen comments that the weatherstrip runs all the way to the end and the screw that holds the stainless steel clip runs through it and I've also seen photos in the Restorer and in other posts that show it mounted short of the forward end of the deck by about an inch, clearing the stainless steel clip screw. Which is correct? Any comments from owners of Bowtie cars? Thanks.
    Keith MacRae
    NCRS #36692
    New Mexico Chapter
    1960 290HP FI
    2013 427 Convertible
    Shade tree mechanic and
    B-52 pilot extraordinaire
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11366
    Re: C1 convertible deck weatherstrip
    Original '57. Maybe later years was under the screw.
    ...and it's original top weatherstrip and top. The top w/strip was integral one piece header and 2 sides. This changed to separate pieces later, late 59 IIRC.
    • Keith R.
      • August 31, 2001
      • 675
      Great pics Richard. Interesting how they cut a "V" shape in the weatherstrip to provide passage for the screw. Hadn't seen that before.
      Keith MacRae
      NCRS #36692
      New Mexico Chapter
      1960 290HP FI
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11366
        Keith, I think the Vee was to help the rubber curve around the edge. You can see the trace of the Vee on the lid just under where the rubber peeled away from it. The screw didn't pass through the rubber.
