1957 Frame serial # - NCRS Discussion Boards
1957 Frame serial #
  • Walter S.
    • August 25, 2016
    • 2
    1957 Frame serial #
    Where located on frame?
    • 43279
    Re: 1957 Frame serial #
    Walter------
    It's located on the top of the driver side frame rail approximately at the mid point of the door opening. Unfortunately, it's extremely hard to see with the body on the frame.
    • Ed H.
      • November 1, 1999
      • 626
      Walter,
      My 1957 had the vin stamped on two locations, where Joe said and going to the rear near the the other stamping was the same stamping.
      my vin number ended in 3745 and early May car.
      • Walter S.
        • August 25, 2016
        • 2
        So, essentially, not accessible with the body on....?
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11364
          The most important factor is how bad the rust is on the top rails. I have been able see it on my 59 and many others with the body on, using a mirror placed under the floor with double-sided tape. Too much scaly rust, no. If the floor to frame is tight there, you can use some wedges to push up on the floor to give more space for viewing. I often use various sized 3/8" drive deep sockets and push in and roll them into the vin area.
          Here are a few photos for reference...
          Here is where both are on a bare frame....
