I have read many forum posts on this subject but still need help please.
I have a 69 AC car. Blower fan weak, only runs on high speed setting.
From what I have read, that should mean the blower motor resistor or connections. I have removed my resistor and both it and the connections look good.
1. If the metal, springs and connections on the resistor look intact, does that mean it is ok, or should I still replace? (see picture)
2. Also, there are 2 cut wires connected to something that looks like a capacitor attached to the top of my blower motor, can anyone tell me what this is, where the wires should be attached and if this may be my problem? (see picture)
3. I have read that upgrading the ground wire can help. Can someone show me a labeled pic or diagram of which is the ground wire coming from my blower motor?
4. I have also read to clean debris from plenum. Is this the hollow box under my resistor? If so, mine looks good.
And my inline fuse towards the passenger side also looks good (I assume the correct one for blower fan but from what I have read the fan would not run on high unless fuses good).
Any and all help greatly appreciated.
