Color question on 65 rodster - NCRS Discussion Boards
  • Glenn S.
    • August 18, 2016
    • 9
    Looking at a 65 car and the trim tag is missing, is there a way to tell original color? On some doc?
  • Ed S.
    • August 6, 2014
    • 1388
    Re: Color question on 65 rodster
    Run Forest Run!
    Ed
    • Glenn S.
      • August 18, 2016
      • 9
      Trim tag, not vin, thanks
      • Joe R.
        • May 31, 2006
        • 1822
        Hi Glenn,
        I think Ed's advice would still stand. I would not mess around with a car with no trim tag!
        Joe
        • Bob R.
          • June 30, 2002
          • 1595
          A car with no trim tag will not fair well in NCRS judging. If all you want is a driver it might not matter to you but the value of the car when sold will be low.
          • Paul S.
            • June 30, 1982
            • 359
            Try and get a light and look up under the dash out by the doors . Or if you can drill the side rivits out on the dash by the doors, if the dash has never been removed . The original color would be under it. Agree , if it was vin tag , no stay away from it . But trim tag , buy the car..
            If the price is right, buy the car
            • Loren L.
              • April 30, 1976
              • 4104
              Noland Adams did some significant Surveys for his 63-7 book. You might think about attending church three times this Sunday and on Monday, contact Noland and provide the VIN and pray further.
              • Patrick B.
                • August 31, 1985
                • 2012
                Unless the car has been painted to a high standard, the original color may still be under the door thresholds, behind the interior door panel or under the carpet. Removing the seat and looking under the carpet cuts for the seat tracks may reveal the original color.
                • Peter M.
                  • May 30, 2013
                  • 361
                  Glenn,
                  Check that the vin plate is original if you are still considering the car. My opinion for what it's worth is to look for a different car.
                  Kind regards.
                  • Glenn S.
                    • August 18, 2016
                    • 9
                    just looking, not buying, I'm in the process of doing a ground up on a 66 roadster,427/390,4sp,a/c,ps,pb,pw,all original matching #
                    white with blu/white int, thanks for reply
                    • Carl N.
                      • April 30, 1984
                      • 592
                      Also look behind rear license plate surround. Often this was taped over on quick paint job.
