Water Pump to Engine Block Gasket Failure- Why did this happen? - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4607
    What did I do wrong, and how can I prevent this from happening again?
    The gasket between the water pump and block on the passenger side blew out during my Sunday drive yesterday. The engine was running at about 180 degrees when it occurred. The good news is the engine was still at normal operating temperature when I shut down even though coolant was gushing out of the engine-to-water pump mating surface. I say the gasket "blew out" because I can see a portion of the gasket sticking out where the leak occurred. It wasn't like that before the leak; I believe the coolant pressure pushed the gasket out a bit.
    I installed the water pump about 1,000 miles ago; no leaks until this failure (the engine is very clean and I diligently check for leaks after every drive). I used the gasket that came with the pump, along with I believe Permatex #2. I'm fairly confident the attaching bolts are tight.
    I've installed a lot of water pumps over the years, but never had this happen. When I repair this mess, what gasket/sealant combination do you recommend?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • 43281
    Re: Water Pump to Engine Block Gasket Failure- Why did this happen?
    Mark------
    The gaskets that I've seen supplied by commercial rebuilders with rebuilt waterpumps scare me a bit. I don't think I'd use them. Having one "blow out" as you've described does surprise me, though. I've never seen that happen. If it were me, I'd use a GM #3860039 or a Fel-Pro 30060. As far as a sealer goes, the Permatex #2 ought to work fine. However, if it were me, I'd opt for a VERY thin coating of Permatex Ultra Copper or Ultra Black.
      • 6957
      Mark, just use a fel pro gasket as Joe says, I personally use 3M weatherstrip adhesive it will basicly weld the gasket to pump and will stop blow out. and proper torque is important.
      • Mark E.
        • April 1, 1993
        • 4607
        Joe, Edward,
        Thank you.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Terry D.
          • May 31, 1987
          • 2697
          Mark
          Did you check the bolts after a good warm up run? The gasket blowout is caused by either the bolt came loose a little or the surfaces are not flat and smooth! Sometimes bolts will loosen up a bit after a good long run. Before I take my 62 on a trip I check all the bolts and nuts I can to make sure none have vibrated loose. Just my old 2 cents.
          • Bruce B.
            • May 31, 1996
            • 2930
            FelPro gaskets with Permatex #2 on all surfaces.
            As Terry said check for tightness on a regular basis.
            Bruce B
            • Loren L.
              • April 30, 1976
              • 4104
              What year car?
                • 15706
                When everything is cleaned up lay the pump against the block with the bolts started, the push the pump against the block and use a .0015" or .002" feeler gage to check the gap. Check around the edges with the pump pressed against the block, then press the pump against the block with the gage inserted and see if it easily pulls out. It if does, either the block or pump mounting surfaces are not flat.
                It's not uncommon for the pump mounting surfaces to be a bit warped after multiple rebuilds over the years.
                I'm not sure how much is acceptable, but I'd say if it's more than .003" you should check both the block and pump with a machinists bar and dress down high spots with a file. Then using a high quality gasket/sealer as previously recommended should do the job.
                • Mark E.
                  • April 1, 1993
                  • 4607
                  Originally posted by Terry Deusterman (11486)
                  Mark
                  That's a good practice. I did check those and other bolt torques ~100 miles after restoration. But not since then.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Mark E.
                    • April 1, 1993
                    • 4607
                    Originally posted by Loren Lundberg (912)
                    What year car?
                    Stock 1970 LS5.
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
                    • Mark E.
                      • April 1, 1993
                      • 4607
                      Thanks Duke. I'll definitely check this as you suggested.
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Mark E.
                        • April 1, 1993
                        • 4607
                        Originally posted by Dave Perry (19643)
                        Just for grins, check the pressure cap for its release pressure?
                        As an aside I had this happen to my 85 when it was 2 years old. The pump to block gaskets were almost "pulverized". I don't recall that I came up with an explanation for the failure. I installed FLAPS gaskets with #2 Permatex, and now almost 30 years and 40K miles later, that repair is still holding. Sometimes $hit just happens.
                        I was also wondering about the pressure. I know pressure builds after shut down, but the velocity of the coolant stream gushing out of the pump/block mating surface was incredible. It just seemed like a lot more than 12-18 pounds.
                        But if the cap didn't release pressure as it should, I'm surprised the pump gasket was the weak link. I would expect a hose to blow off or maybe a seal failure.
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                        • Mark E.
                          • April 1, 1993
                          • 4607
                          I wanted to share the rest of this story.
                          As I removed the water pump to repair this problem, I noticed the two block-to-pump bolts on the right side were not torqued down. They were tightened just enough to contact the lock washers. So it seems this is the root cause of the gasket failure. I'm surprised the seal lasted as long as it did- about 1,000 miles.
                          I originally installed the water pump, so how did this happen? I believe I finger tightened the bolts then wrenched one more turn with the idea of letting the Permatex #2 set up before final torquing. Then I failed to return later for the final torque down.
                          Thank goodness I'm not a professional mechanic.
                          Mark Edmondson
                          Dallas, Texas
                          Texas Chapter
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11364
                            Mark, One more thought, maybe someone mentioned,......
                            Make sure the bolts are not too long and bottoming out into the block. Those are blind holes and you may think they're tight, but not tight enough to hold the pump on as they may be bottomed out. Remove the bolts and check depth with a screwdriver or drift, then measure the bolt to tip below the lockwasher. This may be why they loosened.
                            Rich
                            • Mark E.
                              • April 1, 1993
                              • 4607
                              Thanks Rich; will do.
                              Mark Edmondson
                              Dallas, Texas
                              Texas Chapter
