1967 390HP top alternator adjusting bolt and washers - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Was told I need a flat washer and a star washer on this adjusting bolt, is that correct or what is right? Thanks in advance.
  • Leif A.
    • August 31, 1997
    • 3658
    Re: 1967 390HP top alternator adjusting bolt and washers
    That is correct. In this order...backside of alternator boss, then adjusting bracket, washer, star washer then bolt.
    Leif
      • 6960
      Jerry, To add a something else to Leaf's post the flat washer was typically thicker and slightly bigger dia. that a normal flat washer.
      Also when the bolt and washers are installed the end of the bolt is almost flush with the ear on alternator.so the bolt length was specific.
      • Ray G.
        • May 31, 1986
        • 1189
        I hope you dance
