I need to remove the main section of the luggage stop panel to repair a crack in the fiberglass below it. It appears to be spot welded to the side panels. The side panels don't appear to be easily removable as they are sandwiched between the birdcage and the body. Is there an easy way to separate the pieces without destroying them? What is the best way to reassemble after repairs?
Thanks for any help.
Tom
Tom
