1963 Shifter Boot - NCRS Discussion Boards
1963 Shifter Boot
  • Rob A.
    • February 8, 2011
    • 135
    1963 Shifter Boot
    Are the 3-speed and 4-speed shifter boots (rubber boot inside the console) the same in 1963? Also is there any difference between shifter boots for early cars versus later built cars?
    Rob
    • 43277
    Re: 1963 Shifter Boot
    Rob
    Rob-------
    No, the 3 and 4 speed boots were different. The 3 speed boot was GM #3823347 and the 4 speed boot was GM #3822947. It is possible that early cars used different boots. If so, I have no information on that.
    • Rob A.
      • February 8, 2011
      • 135
      That is the same part number as the automatic shift boot, correct?
        • 43277
        Rob------
        Yes, the Powerglide boot and the 3 speed boot were the same.
        • Bob R.
          • June 30, 2002
          • 1595
          I think the difference is in the shape of the shifter itself. The automatic and 3 speed shifters are just round chrome rods the 4 speed shifter has a notch for the lock out on the reverse so the rubber boot has a little cut out or triangular shape to it.
