65 Fuel injection percolation - NCRS Discussion Boards
  • John S.
    • May 4, 2008
    • 427
    Guys,
    Finally decided to do something about percolation issues I have experienced with my 65 fuelie. As a rule I do like to drive my car and as a rule I don't drive it when the temps are really hot. More of a personal choice as I am a wussie and I like air conditioning! There have been a handful of times where I have been out with the car and it got to be a hot day and have experienced the typical percolation issues common with fuel cars. Granted this issue happens more with today's ethanol fuels then back in the day, there were still issues back then even with higher octane fuels and no ethanol. This has been discussed at length on the TDB. I also know that there are two very well respected fuel injection gurus that visit here and really do not like running ethanol in the fuel units. Big proponents of using racing fuel. These guys truly are the best at what they do and I value their advice immensely. However the cost of race fuel and the availability here in California make it so it's hard to drive the car on a regular basis. The hoops you have to jump thru to get leaded race fuel here are unbelievable. Read on for my results.
    I ordered some DEI 1/2" aluminized sheath sleeve material from Amazon last week for my fuel lines. Comes in 3' lengths which is plenty. Cheap too. It is a completely sealed tube, no Velcro. Had to take the fuel lines (there are 2 on these units, one from fuel pump to filter and one from filter to the fuel bowl). Turns out I could have gotten away with not completely removing the fuel line down at the pump, but per usual I did it the hard way. So I tackled this on Saturday. Took me half hour or a little more. Sleeve material is not easy to get on over the nuts and around the bends but can be done. Did not drive the car on Saturday as we were getting ready to go to the Route 66 restaurant cruise in with the black 67 which has air conditioning! Took the car out yesterday afternoon. Temperature outside was 102 coming down slowly from a high of 106! Drove the car on about a 20 mile loop after warming it up. No percolation issues with Union 76 91 octane ethanol fuel. Even let it idle when I got home. Although that was in the shade it was still over 100 degrees. I wanted to let it idle and heat up some to the point of percolation. Granted the hood was open which I am sure makes a difference. I monitored the temp gage and the coolant temperature at the thermostat which surprisingly were within a few degrees of each other. After 15 minutes at idle the temp had climbed to 230 degrees F. I also monitored the fuel temperature at the fuel bowl. I had done this last year on a 90 degree day and recorded fuel temps in the 165-170 degree range at which point I started having percolation issues and the car died. This time on a hotter day, the fuel inlet temperature stayed in a 145-150 degree range. The insulation dropped the temperature a full 20 degrees! At the 230 degrees I chickened out and shut the car off. I was comfortable with the results I had achieved. The one observation of note at that temperature was that it did not idle as smoothly as it would at a normal temperature on a mild day. But it still idled. Previously when the fuel would start percolating (I believe in the spider assy) I would have to keep the rpm's up to about 2,500 to keep the car from dying. Hopefully no longer!
    I know this fix has been discussed here before, I just thought I would show my results. I can't even guarantee that everyone will get the same results as me. However, for around 20 bucks and a few minutes it is sure worth the try! So far I am happy with them. The sleeving is ugly and I don't like the way it looks but I will live with it until my next National which is in Vegas 2018. There I will be going for my second 97 point score to complete my Duntov try.
    John Seeley
    67 Black/Teal
    300 hp 3 speed coupe
    65 Maroon/Black
    35k mile Fuelie coupe
  • Michael J.
    • January 27, 2009
    • 7155
    Re: 65 Fuel injection percolation
    Thank you John! I have heard, from a fuelie guru around here, that this indeed works well. Unsightly of course and NTFP, but when you want to drive, that is no problem, and I understand some insulating wraps can be taken off for judging easily without any issues. When my '64 gets back in driving shape, this may be the first thing I try, but I will still use non-ethanol premium gas, as it is easy for me to get, and not much more expensive than ethanol laced stuff.
    • John S.
      • May 4, 2008
      • 427
      Michael,
      Now I know why you stay in the "Land of Enchantment"! I am still stuck in "The Peoples Republic of California"!
      John Seeley
      67 Black/Teal
      65 Maroon/Black
      • Michael J.
        • January 27, 2009
        • 7155
        When it comes to useless regulations in your life, and lack of crowd and people, NM is better for sure. But, I do miss those lazy summer days in Ventura cruising the Pacific Coast Highway.
        • Ralph E.
          • February 1, 2002
          • 905
          John,
          Why didn't you try the DEI sleeve with Velcro? Seems it would have been easier to install and remove.
          Agree it looks ugly, but if it works, what the heck.
          • John S.
            • May 4, 2008
            • 427
            Ralph,
            To be honest with you when I ordered it from Amazon I thought it was with the velcro. The idea like you said was that the install would be much easier. When I received it I had to go back and look at what I ordered and I had just screwed up. I did go to the one with velcro and read the reviews and the only negative reviews were that the velcro melted in hotter situations. The sleeving is rated to 400 but the velcro is under 200 degrees f. It worked out and I was glad I ended up with the stuff I did.
            John Seeley
            67 Black/Teal
            65 Maroon/Black
            • John D.
              • December 1, 1979
              • 5507
              John, Nice write up and job you did.
              Go on Ebay friends and type in "DEI 1/2" aluminzed sheath or sheathing. Comes in 36" lengths and is dirt cheap.
              Numerous customers have been using the stuff.
              The repro '59 to 61 and the "62 FI fuel lines are made incorrectly for sure. Before you can even think of DEI on those you better massage them big time. WE discussed this before.
              It's really great that John Seeley was able to achieve some success with just working on the fuel lines.
              The gas is boiling even before it's gets to the FI units. Especially with crappy ethanol.
              Lets go back to the NCRS regional meet at Seven Springs sponsored by my (our) Pittsburgh Tri-State chapter.
              My 63 FI car known as the LWC. (little white car) was sitting behind the huge building along with many others waiting for ops to be done.
              It was 93 degrees that day and really stinking hot. The FI cars were running like crap as I recall. So I showed off with my 63 and put on a demostration.
              Here's what I did. Left the car run for a very long time at idle. Turned the key off and let it set a couple of minutes. The temp gauge climbed sky high.
              Reached in the window and turned the key and the car started right up and ran like a clock (Wrong way to start a hot FI car).
              Anyhow the guys were saying that's becasue I worked on FI units. I said not really.
              I opened the hood and the heat just blasted out. I mean blasted out.
              The LWC had 20 gallons of 100LL AV gas in it. All it's ever had. Air plane fuel.
              Recentlly bought it from a member of my chapter for $4.37 a gallon. Now you can go buy some great racing fuel as most of it is wonderful also.
              Story: Corvette Carlise starts one week from today. MY vendor trailer has a Honda generator. Too small but it works fine running about 6 or 7 fans and many lights.
              When I run ethanol in the poor generator it will run fine until it runs out of gas. When it runs out no way in hell with the thing start. My pal Don Baker and others go nuts trying to get it running while I am in the trailer dying from heat from Bsing about FI stuff.
              Solution to above problem. With 100LL in the generator it runs so nice you can hardly believe it. The generator I am talking about.
              Now when it runs out of fuel and my son or I fill it up again the Honda generator& it will start up immediately and screams out "thank you very much." It would say that if it could talk. The generator absolutely hated ethanol.
              Bringing 5 gallons of 100LL to the show. When 100LL runs it smells sweet. Ours is blue and has a built in leak detector.
              Yesterday I started the generator up. First time since Spring Carlisle. Started on first pull with 100LL. Filled it up to the top with 100LL. Still leary from past failure from ethanol so I made sure I have new spark plugs and tools ready just in case. I am so scared that I will have generator trouble that I carry an extra brand new one with me in the box but I betcha I will not need it. JD
