66 - Alternator bracket - tip or trick - NCRS Discussion Boards
  • Stephen L.
    • August 29, 2007
    • 205
    on a BB, i can't figure this one out - there is a stud coming out of the power steering pump...and one that also acts as the final ex manifold bolt/stud - if i put it one first ... can't get it on the other - and vice versa
    is there some trick position to get this to go on both studs?
    thanks!
  • Stephen L.
    • August 29, 2007
    • 205
    Re: 66 - Alternator bracket - tip or trick
    any thoughts on this one?
    thx!
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11363
      Stephen, I can't picture it and no AIM handy, but is it feasible to double nut the ex manifold stud, remove it, attach the bracket in place over the stud hole, then wind the stud back in and remove the double nuts?
      Rich
      • Joe R.
        • July 31, 1976
        • 4552
        Stephen,
        Sorry but I can't visualize this problem but if you posted up a picture maybe someone can help you. I have assembled a couple of 66 BB Corvettes and never had a problem.
        JR
        • Stephen L.
          • August 29, 2007
          • 205
          i'll take pictures later in the week/weekend - it will be easier to explain that way
          thanks
