Power Window Rebuild - Lubrication - NCRS Discussion Boards
+ More Options
Posts
  • Roger D.
    • May 4, 2008
    • 301
    Folks:
    Continuing on the '72 restoration project and currently rebuilding the power windows. Can someone tell me what kind of lubricant should be used for the guides/tracks? Also how about the latch mechanisms?
    Roger
  • Stewart L.
    • March 1, 1980
    • 355
    Re: Power Window Rebuild - Lubrication
    Corvette Central has a window rebuild how to on their web site that will help you. I tried to link but it didn't want to work.
    • Gary R.
      • April 1, 1989
      • 1799
      I rebuilt my 72's LH window a couple of years ago. I only had white lithium spray grease so I used that and it worked fine but I had a film on the glass every time I closed it. It finally worn down or dried up so no more on the glass but it still works great. Used it on latch too.
        • 43247
        Originally posted by Roger Dupler (48990)
        Folks:
        Roger
        Roger-----
        If it were me, I'd use GM #12377985. You can also use this for many other applications. In fact, it's almost a "one-size-fits-all" lubricant as far as Corvettes go (except front wheel bearings).
          • 11664
          White lithium grease is what was originally used, and I have used that when servicing the tracks. As Gary notes, don't get it on the glass.
