settng glass c2 vent window - NCRS Discussion Boards
  • Jeffrey S.
    • April 1, 2004
    • 133
    I have read the archives on setting the glass and I have a few questions. It says to use oil on the setting tape, what kind of oil, regular motor oil , vegetable oil or ? Also is the tape inserted into the channel of the frame first and then push the glass into the tape or do you put the tape on the window and the push that into the frame . I am working on a 67 coupe if that makes a difference although I don't think it does. Any help will be appreciated, visuals very much so. Thanks Jeff
    • 6950
    Re: settng glass c2 vent window
    Jeff, you can try some dish washing soap. or WD40
    • Jeffrey S.
      • April 1, 2004
      • 133
      Thanks for the reply. Jeff
