Who has had one of these apart and repaired it? Any hints? Po broke both metal tabs off removing the wires. Plus, with the key turned to the right, I have no continuity between the two copper rivets/contacts that hold the (broken off) tabs on. I'm assuming that turning the key to the right aligns some internal mechanism so there is contact/continuity between the tabs/contacts on the outside. I'd like to use this switch because it is original and uses the original D key. This is the late 70-72 type switch. Any help is appreciated.
Theft alarm key switch repair
Re: Theft alarm key switch repair
Mike,Who has had one of these apart and repaired it? Any hints? Po broke both metal tabs off removing the wires. Plus, with the key turned to the right, I have no continuity between the two copper rivets/contacts that hold the (broken off) tabs on. I'm assuming that turning the key to the right aligns some internal mechanism so there is contact/continuity between the tabs/contacts on the outside. I'd like to use this switch because it is original and uses the original D key. This is the late 70-72 type switch. Any help is appreciated.
Did you try contacting Pete Lindahl? He may be able to help you.
JimLast edited by Jimmy P.; August 8, 2016, 09:10 AM.Jimmy
1973 Convertible
L48,M20,N40
Mille Miglia Red/Oxblood
- Top
