1969 390hp oil dip stick with factory AC - NCRS Discussion Boards
  • Keith G.
    • October 31, 2006
    • 316
    White plug, yellow plug or long neck with no plug??????
    • 43221
    Re: 1969 390hp oil dip stick with factory AC
    Keith------
    GM never specified a different dipstick for 1969's with big block and A/C. However, there were 2 different dipsticks used for 1969. Most 1969's, A/C or not, used dipstick GM #3925520. This dipstick had a white plastic plug. Some 1969's received dipstick GM #3959158. This dipstick had a long, angled handle with a loop finger-hold, flattened end, and no plug. Some folks have INFERRED that this dipstick was intended for A/C applications but GM never said so, and as far as I can tell, it was intended to be used for all 1969 big blocks. It did not really appear, at all, until later in the model year, though.
    Some folks think the dipstick with red plastic plug was used for 1969 applications with big block and A/C. I totally disagree with that. I don't think this dipstick even existed during the 1969 model year. In addition, while the above two referenced dipsticks used the same dipstick tube, the red-plugged dipstick uses a different and longer tube. The red-plugged dipstick did later become SERVICE for 1969 (when also used with the longer tube) but I don't think it was ever originally used for any 1969. It did come into PRODUCTION use, though, for the 1970 model year for all Corvette big blocks.
    • Gary H.
      • June 8, 2008
      • 308
      This is my 69 390 hp original
      • Keith G.
        • October 31, 2006
        • 316
        Thanks Gary and Joe, I guess I'll have to return the white plugged one to Paragon.
          • 43221
          Gary-------
          This is the GM #3959158.
            • 43221
            Keith------
            Your car could have originally used the white-plugged GM #3925520, especially if it is an earlier build car. In addition, I don't think that the GM #3959158 is reproduced and originals are very difficult to find. If you do find a used one, I'll bet you won't like the price. NOS? I doubt it. This piece was discontinued in November, 1970.
            • Gary H.
              • June 8, 2008
              • 308
              Joe,
              This makes sense from the info you have given. My car is July, 725XXX
              • Keith G.
                • October 31, 2006
                • 316
                My car came with the correct one, I read some place that it should be white, so I ordered one and did keep my old one. It looks just like the log necked one in the pix.
