F41 Suspension for '66 L 72? - NCRS Discussion Boards
  • John L.
    • 103
    I own a '66 L-72, how does one tell if the car came equipped with F41 suspension? It currently has standard 9 leaf spring and replacement shocks. Thanks
  • Michael J.
    • January 27, 2009
    • 7174
    Re: F41 Suspension for '66 L 72?
    The front sway bar should be 15/16" in diameter if F41, 7/8" on standard BB suspension.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11366
      John, Check these in addition to the front sway bar.....
      Front Springs: How many coils and what is the wire diameter. F41 -> 7 coils(non-progressive). Std -> 12 coils(progressive).
      Rear Lower Shock/Strut mounts: What are the part#'s cast on them? If xxxxx65-66(# faces sky) -> F41, if xxxx029 left, xxxx030 right -> Std
      Rear spindles(if originals): Remove road wheels and identify if the outer faces of the center outward facing hub circles have any unique casting features or are they flat faced.
      Rich
