1964 to 1966 Directional Switch Operation Wiring Diagram - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    I restored a '66 standard steering column and while I was at it I created a crude diagram of the switch operation. I suspect the switch was a replacement as the wire colors of the harness do not match the colors of the body harness plug. However there is a GUIDE marking on it.
    Were the switch wire colors identical to the body harness wires? (edit, a friend just sent me pictures of a original and they're identical to the harness colors)
    Rich
    Here's the diagram with a original switch's wire colors and interconnects.
    Here's the diagram with a reproduction switch's wire colors and interconnects.
  • Joe R.
    • May 31, 2006
    • 1822
    Re: 1964 to 1966 Directional Switch Operation Wiring Diagram
    Hi Rich,
    Great work as we have come to expect from you!!!! Please provide more info on how you restored your column. I am faced with the same job.
    Joe
    • Leif A.
      • August 31, 1997
      • 3645
      "I restored a '66 standard steering column and while I was at it I created a crude diagram of the switch operation. I suspect the switch was a replacement as the wire colors of the harness do not match the colors of the body harness plug. However there is a GUIDE marking on it."
      Rich,
      If that's what you call a "crude" diagram I can't imagine what a professional one would look like Tremendously helpful info with great pics, as always.
      Leif
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11334
        Thank You gents....
        Joe, I have many more photos of the column so when I get time later I'll put something together to show the way I do it.
        Rich
        • Joe R.
          • May 31, 2006
          • 1822
          Fantastic!!!
          Thanks Rich!!!!!
          • Frank D.
            • December 27, 2007
            • 2703
            Some day somebody will put a treatise together on the '63 column and turn signal setup. I should have done it when I rebuilt mine. There is SO much bad info and misconceptions about the one-year-only stuff; especially on that "other" forum...
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11334
              Rebuild thread here for the 64-66 column.....
              https://www.forums.ncrs.org/showthre...Column-Rebuild
              Rich
              PS ... Frank, many years ago I restored a '63 column but didn't take many photos of the details. It's very tedious and many unique parts, I spent much time diagnosing a floppy turn lever and discovered several parts were installed wrong. I truly wish I had taken more time then to detail the process.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11334
                Dave Zuberer saw my diagrams and had some time to spiff them both up. More "Professional" looking for sure.
                Thanks Dave !
