After we installed the engine and transmission back into our 1980, I noticed that the torque converter was sitting tight to the flex plate. I thought that we installed the torque converter properly because I felt the 2nd push after rotating the torque converter, but I am guessing I didn't catch the notches for the oil pump?
Do we have to remove the engine and transmission from the car to fix this problem or is there a trick I can try. I thought of rotating the flex plate with a pry bar to see it the torque converter will go into place on its own.
Danny
Danny
