1972 Corvette Gas Pedal - NCRS Discussion Boards
  • Christopher R.
    • April 30, 2013
    • 65
    I have too much play in the gas pedal before it engages the carburetor. it is really sloppy, i bought a new cable, new holder at the firewall (plastic holder). Any ideas on how to correct this issue to get the most out of my engine? Thanks!
    • 3416
    Re: 1972 Corvette Gas Pedal
    Hi Christopher,
    Is the carburetor connection end of the cable in the proper hole in the linkage and is the spring proper installed so the linkage travels to it's full closed distance?
    • Christopher R.
      • April 30, 2013
      • 65
      I will check it again. thanks for the advice
      • Christopher R.
        • April 30, 2013
        • 65
        any ideas as to how to get a good seal from the carb to the intake manifold? I have tried new gaskets, torquing the bolts in the proper sequence and i still have a leak on the passenger side right next to where the choke assembly is, this is obviously causing me drivability issues and issues with the vacuum operated items like the wiper door and headlights.
        • Mark E.
          • April 1, 1993
          • 4604
          Duplicate post to your other thread started today?
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Christopher R.
            • April 30, 2013
            • 65
            yes, i put it in two places since you were helpful the last time.
