1972 No High Speed Fan - NCRS Discussion Boards
  • Gary J.
    • April 1, 1980
    • 1246
    Trying to help a friend with a 1972 with A/C. It has no high speed blower moter fan. Fan works on other speeds. Checked the resistor on the evaporator core box which is fine, did replace the relay on the evaporator core box. Notice while replacing the relay that wires had gotten hot and melted the plastic connector, the wires are OK. Did replace the plastic connector. Point me in the right direction. Thanks.
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 1972 No High Speed Fan
    Their is an in line fuse in the wire under the master cylinder or close by on the fender well. The wire may be red.
    Lyle
    • Jeffrey S.
      • May 31, 1988
      • 1902
      Gary,
      Over the years I have had this issue several times with my '69 w/Air car. It has always been the same- melted plastic connector and wires at the high speed fan relay. A new relay and wire repair always fixed it. I would re-check the repairs you made to the wires and be sure that there is no damage further up the wire. This assumes that the other speeds are working.
      Jeff
      • Gary J.
        • April 1, 1980
        • 1246
        New relay, checked fuse, fuse OK, still not working....
          • 6961
          Gary, did you try wiggling the electrical connector on the relay with the blower turned on high speed sometimes, as Jeff eluded to the brass wiring connector takes a lot of current so it gets hot and spreads open.
          • Gary J.
            • April 1, 1980
            • 1246
            When I put the new relay on, I put on a new plastic connector. The connector fit snugged.
            • Bill C.
              • July 15, 2007
              • 904
              contact in the fan switch maybe?
                • 6961
                Gary, have you taken a test light to check for power at the orange wire (key-on)? another test is take the test light and put it on the power side ( battery) and touch the black ground to make sure you have a solid ground connection at case. the Blue wire is coming from switch when high speed is selected. purple should be the blower so if relay is working when you select high speed this wire will have power.
