1967 hood prop rod question - NCRS Discussion Boards
  • Paul L.
    • July 7, 2015
    • 38
    Does the hood prop rod have a black or phosphate spring washer under the pivot rivet?
  • Donald H.
    • November 2, 2009
    • 2586
    Re: 1967 hood prop rod question
    I know the C1s or at least for the 1960 had black spring washers as I got dinged at Regional when I had my 1960 judged. There is no mention in the 67 of the lift having black spring washers. I believe my 67 hood support is original and everything is cad/zinc.
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • Paul L.
      • July 7, 2015
      • 38
      Thanks Donald, that's what I thought. I knew the C1's had the black spring washer, all the 67's I've seen had zinc, but wanted to make sure.
