69 differential red tag question - NCRS Discussion Boards
  • Edward C.
    • August 13, 2014
    • 151
    Can someone confirm the correct lettering that should be on the red differential tag used on 69's? On page 106 of the 4th addition JG says the tag should say "USE POSITRACTION DIFF. LUBRICANT ONLY". I was under the impression it should read "LIMITED SLIP" instead of the "POSITRACTION".
    thank you,
    ed
    • 43271
    Re: 69 differential red tag question
    thank you,
    ed
    ed--------
    The "Limited Slip" tag was a later iteration which also became SERVICE for 1969.
    • Edward C.
      • August 13, 2014
      • 151
      Thank you Joe,
      ed
