Points Distributor dwell versus point gap - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    Don't they give the same tuning result, just obtained by different means ? I don't have a dwell meter (say 30-34 degrees spec), but I do have a feeler gauge (say 0.016", used points). I'll assume that the feeler gauge method involves more work.
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Points Distributor dwell versus point gap
    If 30* dwell = 0.016" gap, then yes, same-same.
    • Larry M.
      • January 1, 1992
      • 2701
      In the early days, just about all of us used feeler gages. They work just fine, but take a bit of time to get the gap just right. However, I have always liked using a dwell meter, since my accuracy with a feeler gage is not always the best.............especially for distributors in the rear of the engine block and the engine still hot.
      Larry
      • Gary R.
        • April 1, 1989
        • 1804
        GM v8 I set by dwell, all the others of the "point era" I set with feelers on the distributor block/cam high point.
