I have a 66 327/300 PG with Holley carb.  Recently noticed that the carb whistles after the engine is warm.  Other posts suggest that this might be the carb base gasket so I will check this.  Also wondered if the PCV valve could be involved.  Also, the engine tries to stall sometimes but usually recovers after a hesitation - but not always.  When it stalls I can restart immediately.
I recently had electrical trouble which seemed to be burnt wires at the starter solenoid. After replacing these wires everything seemed fine until the carb started whistling. When it began stalling I wondered if the electrical problem was back but the clock continues to run and I can restart immediately - when I had the electrical problem everything was dead (clock stopped, total silence when I tried to restart).
Any ideas? You guys have been very helpful.
Noel Barbulesco
Noel Barbulesco
