1963 carb linkage bushing - NCRS Discussion Boards
  • Bob R.
    • June 30, 2002
    • 1595
    Trying to figure out which plastic bushing is correct.
  • Leif A.
    • August 31, 1997
    • 3645
    Re: 1963 carb linkage bushing
    Bob,
    The lower right (off white) nylon bushing is correct.
    Leif
      Bob -
      The top right bushing (larger diameter, to accommodate the black rubber grommet for the throttle rod at the carburetor throttle lever) is correct, and the flange on the bushing goes on the same side of the rubber grommet as the spring end or cotter pin that retains the carburetor throttle rod to the lever, as shown in the Assembly Manual.
      • Leif A.
        • August 31, 1997
        • 3645
        This is another current thread regarding the same bushing...just for different years. Was there a change??
        https://www.forums.ncrs.org/showthre...ing-gm-3707713.
        Leif
        • Joe R.
          • July 31, 1976
          • 4551
          Leif,
          The wide bushing was sold in the 70's as a replacement for the earlier narrow base bushing. The narrow original bushing was used on both ends of the accelerator rod for 63-67. Don't know about later C-3's.
          JR
          • Leif A.
            • August 31, 1997
            • 3645
            That's what I thought, Joe. Thanks for clarifying. The wider rimmed bushing seems to make more sense, as John described...but, I had seemed to remember that the narrow base one was correct.
            Leif
