This one ends with a whimper. Duke was on the right track with a post re: checking the fuel line strapped to the frame near the exhaust manifold. I split some rubber hose and used that as insulation on that section of fuel line, but to no avail. Today, a friend noticed that the line from the fuel pump outlet passes very near the block. I gave it a slight tweak to widen the air gap with the block, slipped a split piece of tubing over it for insulation where it passes the block, and "voila!", no more stumble and die.
Thanks everyone for helping troubleshoot this nagging problem.
Steve
Steve
locally, need to order. Jegs has it
.....Right next to that nice original sharp edged hose clamp on the fuel pump fitting.
We've been fighting a stalling problem for quite a while, along with some other ghosts. We lost much hair on this one. Sometimes you just have to wing it.
