1969 Headlight Support Bolt Size? - NCRS Discussion Boards
  • Mark H.
    • June 19, 2016
    • 23
    I am looking for the correct thread pattern and bolt size for the three bolts that secure the 'actuator bracket' to the headlight support (headlight frame) and if they use a washer (and/or lock washer).
    Any help is appreciated.
    Mark
    • 43247
    Re: 1969 Headlight Support Bolt Size?
    Mark
    Mark------
    5/16-18 X 5/8" untrimmed (indented) hex head screw with captured conical flat washer. Gray phosphate finish.
    • Mark H.
      • June 19, 2016
      • 23
      Thanks Joe for the info and fast reply.
      Am I correct in guessing this bolt is not similar to any of the other bolts used on the headlight assembly?
        • 43247
        Mark------
        The same bolt was used in several other positions on the headlamp assembly.
