63 327/340hp Idler Pulley - NCRS Discussion Boards
  • Thomas S.
    • February 7, 2016
    • 618
    I'm replacing the waterpump and cleaning the front of the engine while i'm in there and i'm trying to deter if the idler pulley is correct. July 63 build, 327/340 HP, No PS or AC. There are markings on the back side of the bearings but 1 number short of a typical GM part number. Don't want to paint and install it if it's not the right one.
    It reads
    885198 New Departure Made in USA
    Does it look to be correct?
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
  • David L.
    • July 31, 1980
    • 3310
    Re: 63 327/340hp Idler Pulley
    Your idler pulley looks correct to me. The GM part number is 3829191. The 885198 number is a bearing part number made by New departure. You can buy a 885198 ND bearing on Amazon for $12.35 plus shipping.
    Dave
    • Thomas S.
      • February 7, 2016
      • 618
      Thanks for that info. So an original or NOS would not have had that bearing?
        • 43272
        Thomas------
        It's likely an original bearing. Many original GM-New Departure bearings had 6 digit part numbers. This bearing would have been part of the GM #3829121 idler pulley assembly.
          • 6955
          Dave
          Dave are you sure its still available on amazon? could not find it. thanks,Ed
          • David L.
            • July 31, 1980
            • 3310
            Ed,
            Below is a link to the bearing sold on amazon.
            Dave
            https://www.amazon.com/Departure-885.../dp/B00DBOS7OI
              • 6955
              Dave thanks, I order one to keep as a spare.
              • David L.
                • July 31, 1980
                • 3310
                Ed,
                It may or may not have the exact same stampings as the 1963-1965 version.
                Dave
