1963 Lower rear shock hardware - NCRS Discussion Boards
  • Thomas S.
    • February 7, 2016
    • 618
    I replaced the rear shocks on my 63 with KYB's. There were non-original Delco's on the car. The hardware on the old set was not correct and consisted of a flat washer, lock-washer, and thick nut. There were no seperate inboard or out-board rubber bushings because the lower shock eye already had a pressed in bushing in it.
    The KYB's also had a pressed in bushing as do most current shocks on the market. I ordered correct mounting hardware to get the cup washer and the kit came with the rubber bushings. Should I have pressed out the rubber bushing from the lower shock eye and used the in-board and out-board bushings from the kit, or is it ok to simply use the pressed in bushing on the shock?
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
    • 43277
    Re: 1963 Lower rear shock hardware
    Thomas-------
    Do not remove the existing bushings from the new shocks. You will gain absolutely nothing. Use the new shocks as-is with the hardware from the kit. Remember, the cupped washer is installed with the cup facing outward.
    • Thomas S.
      • February 7, 2016
      • 618
      Thank you for replying. That's what figured.
      Tom
