C2 Fuel Gauge Sender Fit - NCRS Discussion Boards
  • Chris D.
    • November 1, 2002
    • 198
    Having trouble getting new sender into the tank. I get past the float and sock but can't seem to maneuver the rheostat housing through the port. New part has much tighter bend radius than the old part on the major bend. This is a Long Island offering purchased over a year ago. The bad sender being removed was a service item I installed 25 years ago so I'm confident it is correct. New part designer read 1" bend radius and built 1" bend DIA. Funny thing is it made the part much more difficult to fabricate.
    Anyone have recent experience getting this item installed? I'm leery of altering the bend as this new one is stainless and no doubt tough to work with. Would dropping the tank help?
    I'll be calling LI after the holiday. Certainly if this part can't be installed they have been alerted and fixed the issue long ago. I was just looking forward to reading my gauge again this weekend.
    Thanks for your insights.
    See pics how tight bend reduces clearance.
    Chris
  • Jeffrey S.
    • April 1, 2004
    • 133
    Re: C2 Fuel Gauge Sender Fit
    I recently put one in and had no trouble fitting it thur the hole in the tank. The tank was out of the car and was upside down but I don't think that makes a difference , maybe makes it easier but not necessary . I think it's all in folding the float arm and tube together as you put it thru the hole patience is the key here . I can't remember where I got my unit the only problem I had was the rubber gasket I got with the unit was too thin and I had to use one I had ordered separetly by mistake thinking the unit didn't come with a gasket. hope this helps Jeff
    • Chris D.
      • November 1, 2002
      • 198
      Jeffrey,
      Which vendor did you buy your sender from?
      Chris
      • Robert B.
        • March 1, 1992
        • 265
        just put one in last night ( corvette central) got do some turns and twisting but it will go in. a little push here and there. good luck.
        • Chris D.
          • November 1, 2002
          • 198
          A lot of bending t******* and maybe some swearing and its in. While the reproduction parts coverage for our mark is extensive, some really basic engineering often gets lost in the process. Like can it be installed.
          Thanks for your insights, gentlemen.
          • Chris D.
            • November 1, 2002
            • 198
            "T*******" as in the use of metal trim shears. Not aware of modern usage that would suggest the asterisk treatment. Guess I'm just old.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11364
              Yes all repros are a bit tougher to install. Usually the rectangular sending resistor "box" corner is the fit issue. There are small screws holding it together and one hangs on the tank edge.
              When tank is in position, the tube hose end hits the chassis frame. It's not as simple at it may seem as you've discovered and a little t w e a k i n g is usually necessary.
              Rich
              ps the software that this site uses has a "bad word" flag and for some reason that word is on the list and modifies it.
              Use spaces between letters next time.
              • Jeffrey S.
                • April 1, 2004
                • 133
                Unfortunately I don't remember, this project has been going on for over 10 years and I bought the tank and sender when it first started , it may have come from corvette central but I'm not sure.
                • Jeffrey S.
                  • April 1, 2004
                  • 133
                  Just found the catalog that my supplier used when I bought the tank from him and the vendor was corvette America . Hope this helps Jeff
                  • Kim C.
                    Chris - the item in the photo is not the part we sell at LI Corvette - - we sell the K&B sender - looks like the one on the right, not the tight curve in the left of your photo -- (I looked thru your purchase history and do not see you purchasing a sender from us directly) ?
                    in any case - the sender we sell is the K&B part, ethanol compliant - see photo >
                    Chris
                    • Joe R.
                      • July 31, 1976
                      • 4552
                      KIM,
                      Thanks for clearing that up as I've ordered several senders from LI and never had a problem with any of the installations.
                      It's nice to see LI on the NCRS Board and tell Richard we all said HI as we love LI as you ship the same day and parts are always in stock.
                      JR
