OK now the next faze of my 72 BB build - NCRS Discussion Boards
  • Rey S.
    • April 1, 1995
    • 277
    Is it OK/permissible to route the fuel (braided SS) line up the back of the engine and bring it in to the back of the carb rather than the front?????
    Thanks Rey
  • Keith B.
    • September 15, 2014
    • 1604
    Re: OK now the next faze of my 72 BB build
    Seems like a lot of work for little to no gain. What about the fuel pump? What's wrong with the factory routing
    • Mike E.
      • February 28, 1975
      • 5141
      I'm confused--if you are using a very non-stock item, what is the issue about being "permissible"?
      • Rey S.
        • April 1, 1995
        • 277
        Hi Mike --- absolutely not stock mechanically. I was concerned about heat with heads in that narrow area.
        • Rey S.
          • April 1, 1995
          • 277
          Hello Kieth, Sorry for not including enough base information. The reason for wanting to route the fuel line as described was to make it less noticeable. I am doing the best that I can to hide lines and wires considering the limited space available. The electric fuel pump and filter are mounted in the back next to the tank. The trans cooler is a stand alone unit in front of the radiator and AC condenser.
          Thanks for your concern.
          Rey
          • Douglas L.
            • May 8, 2015
            • 181
            Assuming that routing is done properly(no contact where chaffing could occur) I see no issues. The heat difference between the new and stock location is negligible and I have been forced, during engine swaps, to route braided hose too close for comfort(in my opinion) to exhaust manifolds in the past with no ill consequences.
            • Rey S.
              • April 1, 1995
              • 277
              Hi Douglas,
              Thank you for the info!
