Hi Guys
I was out all day today in my 72, stopped at several places no problems then stopped to fill up. I always have filled the tank to the top and let it settle and never noticed anything. Well about 1.5 hours later I went out to drive home and found about a qt of gas leaking out.
I expected to find one of the rubber hoses at the fuel pump leaking but it was under the LH side, behind the front tire. The only thing there is the original vapor can and I clearly saw there was gas dripping out of it. I didn't see any rubber line there though and couldn't get under the car where it was parked.
I made sure there was no issue for a fire and started it up to idle. The drip stopped and I drove home about 15 miles without issue.
I don't have my assembly manual here to look at the plumbing of the tank. I believe there is a black plastic vapor check valve on the tank with a hose running down the LH rail to the charcoal can tucked under the fender. I think I over filled the tank and it ran down to the can but the hose wasn't connected or it popped off?
Does anyone have a picture of this or have experienced this before?
Thanks in advance, I am going to go back out to see if it's leaking again.
Gary
Gary
