My '67 factory AC compressor is not coming on when I pull the "AC" knob. Compressor's not frozen just not engaging. Fuse OK.
1. Where to check no voltage problem? Hope it's not switch associate with "pull AV' knob. Understand very difficult to get to. Isn't there a second switch on top of heater box- not talking about the one that directs hot H2O to heater?
2. If I want to "hot wire it on so AC will be on when key is on, where from- horn relay hot side? Or is there a source on same side of engine compartment as AC? I see a couple of connectors coming out of wiring harness just above blower motor that aren't connected and appear to be "extra" nonused connectors (unless they're supposed to connect to something, but don't see where)
