1970 Corvette Brake Master Cylinder - NCRS Discussion Boards
  • Daniel S.
    • January 14, 2011
    • 309
    Hi Gents,
    I'm looking for reference photos of an original 1970 Corvette brake master cylinder. Are there original/factory units dated or just have a part #? Do they have bleeders?
    Anyone have a good source to rebuild/restore a core back to factory original specifications? Unit will be for my '70 LT1 convert.
    Dan
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 1970 Corvette Brake Master Cylinder
    My 1970's brake master cylinder does have bleeders. On the front of it there is a stamping of one letter, looks like a "G".
      • 15606
      David
      Original 1970 (and 1968 to 1972 for that matter) master cylinders have a casting number on the inboard side, two steel (silver color plating) bleeder screws and most will have a Julian code date stamp on the forward brake line port machined surface. They will also have a two letter "broadcast code stamped on the front semi-circular machined surface. A good description of the finish as well as the casting numbers and broadcast code is in your version of the 1970-72 TIM&JG. There is some controversy over the casting number for the power brake master cylinder, but it involves the numbers 6 and 8 so if that is your situation read the number without too much concern for those two numbers.
        • 3416
        Hi Dan,
        Here are a couple of pictures from my 71 standard brakes master cylinder.
        They illustrate the the 2 stamps on the master cylinder and also one on the distribution block you might want to check for.
        Here's the Julian date stamp. the surface it's on is a machined surface so is unpainted even
        though it looks painted in the picture. 0 336
        And a Julian date stamp on the distribution block. 0 259
          • 43244
          Jim------
          If it's a power brake master cylinder the code should be "PG". So, the "P" may be very faint or, perhaps, it was somehow omitted.
