67 327/300 water pump - NCRS Discussion Boards
  • Enzo C.
    • January 12, 2012
    • 536
    I wanted to ask if the bolts on the water pump have a flat or lock washer on the 4 mounting bolts? The new JM does not specify ??
    Enzo Colosimo
    Ncrs Ontario Chapter Chairman 🇨🇦
    ENZ-Z06/67
    • 43277
    Re: 67 327/300 water pump
    Enzo------
    No washers at the bolt-to-pump interface. However, if a stud is used at the left upper position, there are split lockwashers used for the alternator brace but not between the stud and the pump casting.
    • Enzo C.
      • January 12, 2012
      • 536
      Hi Joe, I have no stud but just the 4bolts... I will remove the lock washers so will have just a bare bolt to water pump ...
      Enzo Colosimo
      ENZ-Z06/67
        • 43277
        Enzo-------
        While GM never used washers for the waterpump retaining bolts, they should have at least used flanged head bolts, but they never did. The use of a standard hex head bolt without washer interfacing directly with the pump casting was, in my opinion, a bad idea. But, that's what they did. Flanged head bolts would have probably cost 1/4 cent more each.
