69 Fuel Level Indication - NCRS Discussion Boards
  • Dennis W.
    • July 27, 2011
    • 63
    Hello all - Over the past few months, my fuel indicator has indicated less fuel than is actually in the tank. It is getting worse over time. With a full tank the gauge shows 3/4 at best and goes down from there showing close to empty when it has probably half a tank remaining. Thoughts or advice??
    Dennis Wright
    '69 White/Red Coupe
    L46/M20/PS/PB/AC
    404/388-7686 (c)
    • 43213
    Re: 69 Fuel Level Indication
    Dennis------
    My guess would be that the the fuel level float has become "heavy". The float is a foam-like plastic material and can, over time and degradation of the sealer, absorb gasoline and become heavy. Therefore, it does not "float" as-designed. I don't think that GM ever offered the floats separately but they may be available in the aftermarket.
    Of course, your problem could also be the result of a failing fuel gauge tank unit. That would necessitate a new unit.
    • Dennis W.
      • July 27, 2011
      • 63
      Thanks, Joe. Since the sending unit will have to come out, new gasket, etc., any reason not to replace the whole thing?
      Dennis Wright
      '69 White/Red Coupe
      L46/M20/PS/PB/AC
      404/388-7686 (c)
        • 43213
        Dennis------
        Replacing the entire assembly is probably the way to go. However, I understand that some of the replacement units available today are off-shore manufactured and inferior. The current GM replacement, GM #19480449, might be, too; I'm not sure. If you could find an NOS GM #6428164 that might be the best thing.
        • Dennis W.
          • July 27, 2011
          • 63
          Thanks much!
          Dennis Wright
          '69 White/Red Coupe
          L46/M20/PS/PB/AC
          404/388-7686 (c)
            • 43213
            Thanks much!
            Dennis------
            I find that the 19480449 is no longer available, anyway.
