1967 Turn signal flasher - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1585
    Is the correct number for a 1967 turn signal flasher a TunSol 323?
    I need to find a good functioning replacement.
    While I'm asking, what would be a correct functioning replacement for a hazard flasher? Also for my 67.
    Don
  • David L.
    • July 31, 1980
    • 3310
    Re: 1967 Turn signal flasher
    For 1967, according to my notes:
    Yellow Plastic Tung Sol 323 without "DOT". I have several NOS with the "DOT".
    I believe that the hazard flasher is a Signal-Stat 175, GM # 3883794.
    Dave
    • Donald O.
      • May 31, 1990
      • 1585
      Dave
      Thanks Dave,
      I have an original dated Tung Sol 323, just didn't want to use it. Now for the hazard flasher....
      Don
      • Larry M.
        • January 1, 1992
        • 2688
        Don:
        Checkout Ebay and LICS website. You should find what you need. As David already stated, originals did not have DOT markings.
        According to the 1967 JM, Signal flashers were TS 323 or Signal Stat 145. Hazard flashers were TS 552 or Signal Stat 170 or 175.
        Larry
        • Donald O.
          • May 31, 1990
          • 1585
          Dave
          Thanks Dave,
          Don
          • Bill K.
            • June 27, 2013
            • 48
            Here is a photo of the flasher in my early (Sept 66) 67 big block.
