62 Leaf Springs - NCRS Discussion Boards
62 Leaf Springs
  • Eric E.
    • November 1, 1998
    • 254
    62 Leaf Springs
    I have been reading a number of old posts and wanted a consensus of what I have found so far. It looks like for a "driver", re-arching original springs is not the solution. The ones I have are somewhat saggy and have some surface rust and all the post lead me to believe that these are not suitable for use unless trailered. Is that still the thought or can someone shed a new twist to this?
    thanks, Eric
    • 43277
    Re: 62 Leaf Springs
    thanks, Eric
    Eric-------
    How do you know the springs are "saggy"?
    As far as rust goes, if it's only surface rust, that's no problem, at all. The problem occurs if any of the leaves have PITTING type rust.
    • Eric E.
      • November 1, 1998
      • 254
      Re: 62 Leaf Springs
      Hi Joe.
      The springs are in my shop back home, I am stuck in Atlanta with a weather delay to my flight otherwise I would post a picture or two. They both are off the chassis and have minimal arch. I have the set of replacement springs that came on the car when I bought it and the arch is considerably more when sitting side by side.
      As for the rust I will need to disassemble them and brush them down to see how the surface condition is. One leaf is broken but I do have a replacement.
      Eric
      • Terry D.
        • May 31, 1987
        • 2697
        Re: 62 Leaf Springs
        Eric
        Most of the replacement springs I have seen have too much arch and the car sits a little high in the rear. You could send your springs to Eaton and they will re arch them the right way and you will get them back just like new. I believe they are the original makers of those springs.
        • Gary B.
          • February 1, 1997
          • 7068
          Re: 62 Leaf Springs
          Terry,
          According to John Hinckley, Eaton Detroit Spring was not an OEM supplier to GM. But they have been around for more than 65 years and they know what they're doing. Although in the case of their C2 reproduction springs, they differ cosmetically from original GM C2 springs.
          Gary
          • Loren S.
            • November 1, 2002
            • 172
            Re: 62 Leaf Springs
            Here's a link to a great article on the subject from John Hinckley, which will download in PDF:
            • Pat H.
              • December 1, 1996
              • 421
              Re: 62 Leaf Springs
              I believe that Rockwell was the OE manufacturer
              • Eric E.
                • November 1, 1998
                • 254
                Re: 62 Leaf Springs
                Here are some pictures of the 62 springs. As you can tell, the condition and arch are a mess. The two sets have different free height and one has a broken leaf. The replacement leaf I acquired is bent.
                The pictures also show the some of the surface condition but I won't know the extent of the corrosion until they are pulled apart.
                Got to love these odd, short run parts! Eric
                • Bob R.
                  • June 30, 2002
                  • 1595
                  Re: 62 Leaf Springs
                  Not all old springs can be saved or re arched. I sent the spring from my 63 to Eaton and they returned it to me with a note that it could not be re arched as it had too much corrosion I thought my spring looked much better than yours.
                  • Pat H.
                    • December 1, 1996
                    • 421
                    Re: 62 Leaf Springs
                    I called Eaton regarding my springs and they said if there is still an arch in them, you are better off to leave them alone. There is no guarantee that the re-arched spring will be any better than what you have. I was also warned that sandblasting may cause the spring to further weaken. I used a 3" scotch-brite type disc on a air angle tool to take the rust off. They were actually in pretty good shape, so new liners and re-bounded them and they have been fine for the last 6 years. The Corvette Central band kit is a close as you will get to the original.
                    • Eric E.
                      • November 1, 1998
                      • 254
                      Re: 62 Leaf Springs
                      Thanks, I think I will take them apart and see how bad the corrosion is. I wouldn't doubt the surface between the liners is in worse shape than the exposed. Ultimately, I will see what I find for condition, find specs and see what I would need to replace. Eric
                        • 43277
                        Re: 62 Leaf Springs
                        Eric------
                        Usually, the upper and lower surfaces of the springs will be the worst for wear. Pitting type corrosion is what you have to be the most concerned about.
                        • Eric E.
                          • November 1, 1998
                          • 254
                          Re: 62 Leaf Springs
                          Eric------
                          Thanks Joe, looks like a little disassembly time is coming!
                          • Frank D.
                            • December 27, 2007
                            • 2703
                            Re: 62 Leaf Springs
                            Essentially what I did on the '61 as well; I had some corrosion/pitting but not terrible; my free arch was actually right on spec and so I used the Paragon rebuild kit to put new liners, rebound clips and the little metal dots back in their proper places. A bit of work but the springs have performed well for the last 4-5 years after the rebuild.
                            I emulated the factory crimp on the rebound clips as closely as I could with the off-the-shelf crimping tool I used; not perfect, but close...
                            • Eric E.
                              • November 1, 1998
                              • 254
                              Re: 62 Leaf Springs
                              Hi Frank, where re did you get your specs?
                              Eric
