72 Headlight Assembly - NCRS Discussion Boards
  • Rey S.
    • April 1, 1995
    • 277
    I am experiencing an interference problem on my 72. The front bumper brace/support that protrudes thru the bulkhead at the front of the inner fender well is hitting the mounting bracket for the headlight assembly. I am not finding enough adjustment to the brace to gain enough clearance. My question is, is it OK to shim the headlight mounting bracket to gain the clearance needed ?????
  • Bill C.
    • July 15, 2007
    • 904
    Re: 72 Headlight Assembly
    Rey
    I have done several C3's and never got that pot metal horseshoe bracket anywheres close the the bumper mounting bracket/extension that bolts to the frame rail.
    If that is hitting the the bracket then I would say your car is not centered correctly on the frame and/or the core support is not shimmed sufficiently between it and the front cross member.
    not really sure -- can you post a good picture of whats going on?
    Bill
    • Rey S.
      • April 1, 1995
      • 277
      Hi Bill
      Could you go into more detail on "not centered correctly". I don't fully understand what you are trying to tell me. Pictures are not practical due to lighting.
      Thanks - Rey
      • Bill C.
        • July 15, 2007
        • 904
        first question -- did you ever remove the body from the frame?
        if not, then what I was asking about does not matter.
        if you did --
        the center line of the car body should be inline with the center line of the frame/chassis.
        this way, the body is not more onside than the other.
        if for instance the body was more to the right then there be a good chance the horseshoe mounting bracket could hit the bumper extension on the right side. etc....
        if you want give me a call on my cell.
        it be a lot easier to explain over the phone, than write a dissertation on the TDB..
        850-567-2994
