Sealing options for '64 convertible top windshield header - NCRS Discussion Boards
  • Michael J.
    • January 27, 2009
    • 7119
    On the way home from our NCRS chapter meeting and lunch Saturday, I had to drive through a rain storm. Everything worked fine, except the convertible top, which was switched to the TFP "Kennedy Cut" front welt for Duntov judging, leaked like a sieve. What can I put under that welt to seal better against the windshield header and keep the water out? The car is retired from judging, and so no TFP worries anymore, maybe some foam rubber strip? Thanks for any tips, BTW, picture attached of some cars at the tavern in the mountains we met at.
    • 6941
    Re: Sealing options for '64 convertible top windshield header
    Mike, do you have the front latches adjusted so they pull down the header all the way? If so go to Lowes or Home depot and see what you can find to lay across the header, my friend with a 63 found a 3/4 round piece of foam that work for him.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17657
      Mike, always carry duct tape for anti rain leaking control. As Ed said you can use a round piece of foam or a flat 1 inch plus wide of soft house window sealing on the windshield header trim.
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Michael J.
        • January 27, 2009
        • 7119
        Thanks guys, I do have the latches adjusted tight as they can go, but water always finds a way around without a good seal, these will work I think.
        • Jim S.
          • March 13, 2013
          • 360
          Is the welding the 3/8" and is it mounted correctly 'under' and not in front of the leading edge of the top?
          • Michael J.
            • January 27, 2009
            • 7119
            Yes, it is, from Al Knoch and passed regional and national judging with no deducts, it just won't seal out water, as with many TFP things, they don't work the best in the real world.
            • Jim S.
              • March 13, 2013
              • 360
              I asked because 'normally' the length of material that Knoch provides for the welting is too short to create the correct ends that tuck under the top.
              • Michael J.
                • January 27, 2009
                • 7119
                I know, that is why I got the special length "Kennedy Cut" one they sell when you push them. Went to Canutillo personally to make sure. It tucks under exactly like the pictures I have of the Bowtie '64s.
                • Bob R.
                  • June 30, 2002
                  • 1595
                  These cars leaked when new so it is to be expected they will leak now. My car had a bend in the front bow which caused a gap in the middle of the window big enough to see light through. The bow had to be gently bent back to the proper position and it now seals much better (I haven't driven it in the rain but I am guessing it would still leak at least a little). The Kennedy cut refers to the size of the top material not the front welt it is a slightly larger cut. The welt can be ordered in two thicknesses and the correct one is the thinner size but my car leaked with either of the thickness until I bent the bow back to the proper shape.
                  • Michael J.
                    • January 27, 2009
                    • 7119
                    You're right about the Kennedy Cut, that is what my top is, but they gave me the thicker welt, so I used those magic words when I went to get the correct one, and they knew exactly what I meant.
                    • Robert S.
                      • May 31, 1988
                      • 81
                      Black vinyl electrical tape works wonders and the adhesive does not dry out or transfer. Start with a piece of tape on the top and half lap additional pieces forward until you get to the windshield glass. Been using this for years to rainproof my 60.
