Water pump backing plate gasket - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7070
    Re: Water pump backing plate gasket
    Patrick------
    Here's the definitive answer to the backing plate problem. This backing plate is an exact reproduction of the original backing plate but it's made from a high quality stainless steel (either 304 or 316, I believe). Thus, it's harder and stiffer than the originals and it will never suffer corrosion damage. For my money, the ONLY way to go.
    You can get them from a fellow on eBay known as "h20pumpman1" His name is Michael Scott from Bloomfield, Michigan. He sells these with a gasket that looks just like the current GM gasket for about 13 bucks. Wonderful! I wish these had been available 30 years ago.
    Joe,
    Will that backing plate work on a 3859326 water pump as well?
    Gary
      • 43281
      Originally posted by Gary Beaupre (28818)
      Joe,
      Gary
      Gary-------
      It will work for all 1955-82 Corvette small block waterpumps. However, it will not be configurationally correct for the earlier waterpumps (C1) which used a flat rear plate. The ONLY way I'd use one of those flat rear plates is if it was absolutely necessary for clearance-to-timing cover purposes (but I'd be expecting a leak, especially with a used plate).
      • Gary B.
        • February 1, 1997
        • 7070
        #18
        Thanks Joe. It sounds like a change to consider once my car is finished with the judging process.
        Gary
