1972 Fuse Block Photo Needed - NCRS Discussion Boards
  • Larry M.
    • December 1, 1986
    • 541
    For a 1972, does anyone have a photo of the firewall side of the fuseblock on an out-of-the-car wiring harness that they can post. New, used or reproduction should be OK.
    I need to see that portion of it that accepts the 1/4" bolt that passes into it from the engine compartment and keeps the headlight and engine harnesses held in place.
    I would imagine that 1968 through 1976 or so would be similar enough to be helpful to me.
    Thanks.
    Larry
  • Larry M.
    • December 1, 1986
    • 541
    Re: 1972 Fuse Block Photo Needed
    Moving this back up in case there's someone who can assist. Thanks.
    • Bill L.
      • April 1, 1985
      • 349
      Larry:
      I found this site (dedicated to documenting the frame off of a '71 NOT a '72!!!)..... Maybe it will help?
      The photos are good but not close ups and there is a ton of dirt on the connectors..... here is the link:
      Hope this helps a bit...
      Regards
      Bill
      • Larry M.
        • December 1, 1986
        • 541
        Bill,
        Thanks very much; that's a helpful look at what I need.
        The entire site itself is fascinating.
        Larry
        • Gary R.
          • April 1, 1989
          • 1806
          Larry
          If I remember to bring home my camera I can take a picture of my 72. It's original.
          That is a good site, I did work on that car for Tim. He has gone into great detail on that car.
          • Bill L.
            • April 1, 1985
            • 349
            Larry
            Garry / Larry:
            Indeed that is a good site to visit.... some really great photos..... A clear photo always helps waaaaay more than a "windy" verbal explanation ever will!!! And this site certainly has a wealth of good photos and explanations!!!
            Regards
            Bill
            • Larry M.
              • December 1, 1986
              • 541
              Gary,
              Thanks, I appreciate your offer. If you can do so, please do.
              Re-reading my original post, I may not have been as clear as I could have. I need to see the firewall side (or back, I suppose you could call it) of the fuse block, but without the two engine compartment harnesses in place. In particular, I need a close-up, if possible, of the nut area that the harness retaining bolt threads into.
              Larry
              • Gary R.
                • April 1, 1989
                • 1806
                Hi Larry
                Well that is a bit different, I really don't want to play with that connection after all these years. Sorry.
                • Larry M.
                  • December 1, 1986
                  • 541
                  Gary,
                  No apologies needed. I wouldn't ask, or expect, anyone to disturb an existing wiring harness. That was why I thought an out-of-the-car example would be best.
                  • Gary R.
                    • April 1, 1989
                    • 1806
                    Thanks Larry. I will look through my photos but I don't ever recall pulling that 73 fuse panel out. I might have some of my 69 but I don't know if they are the same?
