C3 Rear Spring Center Bolt - NCRS Discussion Boards
  • Sheldon S.
    • February 28, 1999
    • 474
    Was the centre bolt cut off with something like bolt cutters? Would that be close to the original look or is there some other way to cut it off to make it correct.
    Sheldon
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11298
    Re: C3 Center Bolt
    Sheldon, I'm thinking you forgot to mention ....."center of the ______"?
    I'm guessing.....Rear Leaf Spring bolt?
    • Sheldon S.
      • February 28, 1999
      • 474
      Re: C3 Center Bolt
      Whoops, yes the centre bolt holding the rear leaf spring together. It was cut off with something that left a ragged cut. I am wondering if bolt cutters would be somewhat similar or something else??
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11298
        Re: C3 Center Bolt
        Sheldon,
        I use a hacksaw, leaving a few threads and then peen the end to prevent the nut from backing out. Not sure how it was cut originally. My guess is they simply snapped it off.
        Also check the bolt head to make sure it's not too high. Replacements, even the GM part, have known to be a problem as they bottom out in the carrier hole. Best to measure and grind if necessary before installation.
          • January 31, 1988
          • 43191
          Re: C3 Center Bolt
          Sheldon,
          Rich and Sheldon------
          I don't think it was usually cut off as close to the nut as pictured. However, it was definitely "chopped off", probably with something similar to a bolt cutter. They guy that would know, for sure, is Franz Estereicher.
          • Leif A.
            • August 31, 1997
            • 3601
            Re: C3 Center Bolt
            Rich,
            Had to comment...great pics, as always.
            Leif
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11298
              Re: C3 Center Bolt
              Absolutely correct Joe. I did cut it a tad short. I found a shot of the "before".....
              I wish Franz visited here. I met him years ago and he's quite a wealth of information.
