Hand brake cable ID 1963 - 1965 - NCRS Discussion Boards
  • Keith W.
    • June 30, 1998
    • 375
    Hi see attached pictures one cable has like a threaded bar on the end the other has the round bearing type , the one on the bottom with the two bearing type ends is for a 65 , is the other one for a 63 - before I sling it.
    there about the same length - I guess who ever labeled the top cable up is wrong ?
    thanks Keith
  • Joe R.
    • July 31, 1976
    • 4550
    Re: Hand brake cable ID 1963 - 1965
    The PN 3842936 is listed in the parts book as 64-66. Neither is for a 63. The front cable for a 63 has a hole for a pin that actuates the brake light on the dash panel.
    JR
    • Keith W.
      • June 30, 1998
      • 375
      Thanks JR it doesn't fit a 65 , also the outer casing is too short for a 65 - makes me think it was labelled up wrong thanks Keith
