1965 L76 air filter (foam versus paper) - NCRS Discussion Boards
  • Joseph C.
    • June 10, 2012
    • 17
    I would like opinions please as to the effectiveness of the original foam air filters ( modern reproductions) and how they compare to the paper elements that are now available. Would like to use a repro unit in our car to keep it original but not if it does not do the job. Not talking K&N or other performance filters. Thank you, Duke
    • 43248
    Re: 1065 L76 air filter (foam versus paper)
    Joseph-------
    In my opinion, the paper elements are FAR superior to the original foam elements. Use the paper for driving and install the foam for judging. It's a pretty easy swap-out.
    • Joseph C.
      • June 10, 2012
      • 17
      Thanks much for your feedback, Duke
        • 15706
        Re: 1965 L76 air filter (foam versus paper)
        ...same as my response to this question that you posted on the CF.
        • Joseph C.
          • June 10, 2012
          • 17
          Thanks again Duke, trying to gather as much imput as possible. No offense intended. I guess I am trying to justify the use of the original foam repro on a car that does under a thousand miles a year.
          • John D.
            • December 1, 1979
            • 5507
            The foam elements weren't any good when they were new. We pitched them and went to a paper element.
            Stand to reason the paper will allow more air to pass thru.
            • Ed S.
              • August 6, 2014
              • 1377
              Joseph,
              Go paper..... and.... if you haven't identified a particular brand or part # for a suitable (high quality) paper filter, allow me to save you the time of doing the research - particularly in the TB archives - and suggest the one that appears to be the most often recommended for you L76 application. Get a WIX brand, part # 42070. If you can't find that exact item, go to a NAPA store and ask for their paper filter, part # 2070. It is in fact a WIX 42070 filter. The NAPA part number is not similar to the WIX by coincidence. NAPA price is under $10 but it will likely not be in stock and they will charge you for shipping from their regional warehouse. I got one for my '64 L76.
              FYI - this filter is about a 1/4 inch too tall for the OEM chrome air filter assembly. The chrome lid will stand proud just a bit but, no problem since the rubber gasket on both sides of the paper filter seals tightly against the filter assembly.
              Ed
              • Joseph C.
                • June 10, 2012
                • 17
                Thank you very much, Duke
                • Joseph C.
                  • June 10, 2012
                  • 17
                  Thank you!
                    • 43248
                    Originally posted by Ed Szeliga (60294)
                    Joseph,
                    Ed------
                    WIX is definitely the best in my opinion, too.
                    • Mark E.
                      • April 1, 1993
                      • 4602
                      Is Duke your nickname? Or are you asking for Duke Williams?
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Joseph C.
                        • June 10, 2012
                        • 17
                        Hi Mark,
                        Duke is my nickname.
                        • Ed S.
                          • August 6, 2014
                          • 1377
                          Joe,
                          I believe you are aware that WIX also makes a petty good oil filter too - the type that goes into the non-disposable canister found on early Chevy SBs. I use aWIX #51143 filter in my '64 L76. They produce (or market) the same filter for other vendors - the vendors use their own part # - but I don't have that info.
                          Ed
                          • Joseph C.
                            • June 10, 2012
                            • 17
                            Thanks for the info Ed. I have a spin on now but am thinking of converting back to the original set-up. I never thought I would get caught up in this originality thing but I think I have. Thanks again , I appreciate your time. Duke
                            • Timothy B.
                              • April 30, 1983
                              • 5196
                              Joe,
                              Ed,
                              I believe WIX makes the NAPA GOLD filter, WIX #51143 and NAPA# 1143, same filter.
