Adjusting hood on a C2 corvette - NCRS Discussion Boards
  • Anthony C.
    • May 25, 2016
    • 10
    The front of my hood on my C2 Corvette is high & there is no shims under the hinge, I was told to put a shim under the rear bolt under the hinge on the body side to tilt the hinge, will that crack the hood or the paint?
    • 6960
    Re: Adjusting hood on a C2 corvette
    Anthony, if you add a shim or two to the under the radiator support that should raise the body to meet hood, be careful as I believe the bumper bracket on front inner fender will have to loosened or bolt removed on that side.
    • Russ S.
      • April 30, 1982
      • 2163
      No it won't, but you don't need to tighten the hinge bolts very tight.
      • Michael H.
        • December 1, 1987
        • 733
        [QUOTE=Anthony Chirchirillo (62441);777078]The front of my hood on my C2 Corvette is high & there is no shims under the hinge, I was told to put a shim under the rear bolt under the hinge on the body side to tilt the hinge, will that crack the hood or the paint?[/QUOT
        That will not crack the body or paint and it does work as I did it to my 67 and it did lower my hood.
        Mike
